valves hitting pistons
mobythevan
I bought a 73 240 with a L26 engine in it. The car was in totally unknown state when I bought it. This is the first L engine I have worked on. So I go the engine running, first found that the dizzy timing was off by a tooth or two. Fired up with a lot of noise on top end. Checked valve adjustement, still lot of noise. Pulled the head and found that the valves have been hitting the pistons. It showed 120lbs compression in this shape. Looks like the previous guy had the valve timing wrong. Doesn't look like any damage was really done. I think I'll clean up the tops of the pistons and put it back together and see if the compression comes up with the correct valve timing. What do you guys think?
