majik16106 Posted April 6, 2003 Author Share Posted April 6, 2003 I just dont know about top end power, I really like the Lt-1 t56 swap as well, you know, darius changed my life, haha. I think the sr would work really well but like said above, if the turbo spools really violently then ill be all over the road in the middle of a gear, I think a lt1 with a small (8psi) supercharger might actually be more street friendly than a sr20det with a t67(which would be about the same power level as the sc lt-1.) Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 6, 2003 Share Posted April 6, 2003 I just dont know about top end power, I really like the Lt-1 t56 swap as well, you know, darius changed my life, haha. I think the sr would work really well but like said above, if the turbo spools really violently then ill be all over the road in the middle of a gear, I think a lt1 with a small (8psi) supercharger might actually be more street friendly than a sr20det with a t67(which would be about the same power level as the sc lt-1.) Actually I remember a post from Darius stating that his car was somewhat undriveable. He would lose the rear end constantly, even with the wide rubber he had. He would break the rear tires at 70MPH with little effort, so your statement above may not be all that accurate. Personally, I think that "problem" is one I would love to " have to deal with". Tim Quote Link to comment Share on other sites More sharing options...
majik16106 Posted April 6, 2003 Author Share Posted April 6, 2003 I just wish I could find something that would make the car insane fast on the road, but not insane hard to drive, i knwo its kind of a contradiction but every car has a perfect point, I cant seem to pin point it on the Z, with a heavily modded rear end, coil over suspension and roll cage the chassis is fine, I can put 17x11 with a 335 DR if I want. I drive a 400rwhp 3rd gen supra and it works great, i just wish I had a bit more torque, I was also thinking a 2jz with a smaller say sp57/60 turbo would be great too, I just love shooting around traffic, I would like th car to be super fast between say 30-100mph, but stay pretty straight. I dont care about running 10s or anything like that, I enjoy driving around. If i wanted to go 10s Id just do the GN swap, but id kill myself driving around on a street with that, besides, id much rather keep the manual trans... Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted April 6, 2003 Share Posted April 6, 2003 Tim, I promise you it's NOT a problem you would enjoy. Never mind the potential for breakage, having to watch the throttle application is a PITA. I have that problem with my Supra now although warmer weather has helped SOME. Nothing worse than stepping into it and losing traction just as you start to really get rolling. Be that a V8 or turbo smaller motor it's no fun. My turbo breaks the tires loose on it's minimum setting - 1.2BAR - in the first three gears. When it's cool out 4th can be a little dicey at times too, especially if the road isn't perfect. Losing traction at those speeds is NOT enjoyable. Drag radials will go on the car shortly and should really help now that weather has improved. If I run a weaker spring then I cannot make full boost when I run race gas (2.2BAR) I'm told. I may try it though Quote Link to comment Share on other sites More sharing options...
zed660 Posted April 19, 2003 Share Posted April 19, 2003 majik16106 If you haven't already seen this post on ClassicZcars.com you may find it interesting. http://www.classiczcars.com/photopost/showgallery.php?cat=500&ppuser=3241&thumb=1 Regards, Zed660 Quote Link to comment Share on other sites More sharing options...
majik16106 Posted April 22, 2003 Author Share Posted April 22, 2003 Good to know, yah I went in a ride in a car last night that changed my whole way of thinking, i really think this is what ill do, or i might actually do a 7mgte swap, one of the two is going into a old z, i gotta clean the supra up a little then its go time ont he Z project. Quote Link to comment Share on other sites More sharing options...
Guest FullBoostOrBust Posted June 6, 2003 Share Posted June 6, 2003 Zed660, Wow, thanks so much i have been on the hunt for a SR powered Z. I was curious on how the engine mounts would come about with a 4 cyl in the Z. The custom mounts are moved up alot on the engine. Very nice, i'm trying to contact the owner and see about getting some of those mounts, anyone know what rear he is useing from the pic? http://www.classiczcars.com/photopost/showphoto.php?photo=3245&password=&sort=7&thecat=500 I got a R200 turbo diff with 3.90 gears. Think i will have any problems with a custom drive shaft coming out of the SR20 tranny into the R200? Any info is greatly appricated! Quote Link to comment Share on other sites More sharing options...
Guest GoaTSLonG Posted June 7, 2003 Share Posted June 7, 2003 hey i have an sr swapped 240sx and the powerband is perfect and not too peaky although im probly only putting down like 250rwhp. I know a guy who has a 2nd gen rx7 with an sr swap, i think its pretty fast too. Quote Link to comment Share on other sites More sharing options...
Taffy Posted June 13, 2003 Share Posted June 13, 2003 My friends shop, LS Automotive specializes in SR20 swaps into the 240sx. If anyone wants a swap into a Z, we would love to do it!! We are in Baldwin Park, California. Thanks, ERIC. Quote Link to comment Share on other sites More sharing options...
ToplessZ Posted June 29, 2003 Share Posted June 29, 2003 Hey Taffy that link in your post is no worky. What would you guys charge for an sr20det swap if the complete setup was supplied to you first. Im curious. Quote Link to comment Share on other sites More sharing options...
