R230
Guest 3154tm
Guest 3154tm
hi all,
i' m new to the group so i did a quick search, but couldn't find the info
i was looking for. hopefully, one of you longtime members can point me
in the right direction. trying to determine if the R230 differential in the
infinity q45 can be used as a direct replacement for the R230 used in
various Z cars. i realize the ratios are different but are the external dimensions( length, width, flanges,etc) exactly the same? thanks.
frank
Guest 3154tm
wow, this group has more depth and width than any i've ever seen! thanks
for the replies. is the q45 r230 longer because of the case or does it have
a different pinion flange? if so can this flange be swapped out with one from a z32 r230 diff? thanks.
frank
