Guest cw280z Posted April 8, 2003 Share Posted April 8, 2003 pump more oil than an f-54 with a p79? my parts car has a p90 on it and i was wondering if there is a difference in the oil pumps also? thxs Quote Link to comment Share on other sites More sharing options...
Mudge Posted April 8, 2003 Share Posted April 8, 2003 So far as I know, only the turbo pump has a higher PSI, I dont know if the volume is different but its somewhat likely. Most OEM pumps are fine for any use, more does not always neccessiarly mean more of a good thing, unless you genuinly have a need for it. Quote Link to comment Share on other sites More sharing options...
Guest cw280z Posted April 8, 2003 Share Posted April 8, 2003 8) well idoubt it also,but thanks for entertaining the idea. Quote Link to comment Share on other sites More sharing options...
Mudge Posted April 8, 2003 Share Posted April 8, 2003 10 pounds for every 1000 RPM is the rule of thumb I've heard. Quote Link to comment Share on other sites More sharing options...
Clifton Posted April 8, 2003 Share Posted April 8, 2003 The turbo pumps have a longer gear. 1.570" compared to the N/A's 1.372". You can adjust the pressure of either pump. I would run the turbo pump even if the pressure was the same. more volume will give you more pressure at lower rpms before the relief setting is reached. Quote Link to comment Share on other sites More sharing options...
