turbobluestreak Posted April 9, 2003 Share Posted April 9, 2003 I was looking at the wiring diagrams for the afc's and All you need to run it is power ground air flow signal rmp signal throttle signal so I know where all are but the throttle signal and I'm not sure where the rmp signal is but I know it's there. So what could I do for the throttle signal to make this work?? tbs Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted April 9, 2003 Share Posted April 9, 2003 It depends on what the AFC expects to see on a throttle signal. The Z31 is like the Z and ZX, just an idle signal and a full throttle signal. At worst, just get a TPS from another car that does provide the right type of throttle signal. I think it wants an RPM signal, taken from the -COIL. Quote Link to comment Share on other sites More sharing options...
turbobluestreak Posted April 9, 2003 Author Share Posted April 9, 2003 thanks bud for the help also I need to know where did you wire pin 6 to in your harness I don't know where to put it and never hooked it up. tbs Quote Link to comment Share on other sites More sharing options...
