would an apexi afc work on a first gen 300zx ecu??
turbobluestreak
I was looking at the wiring diagrams for the afc's and All you need to run it is
power
ground
air flow signal
rmp signal
throttle signal
so I know where all are but the throttle signal and I'm not sure where the rmp signal is but I know it's there. So what could I do for the throttle signal to make this work??
tbs
It depends on what the AFC expects to see on a throttle signal. The Z31 is like the Z and ZX, just an idle signal and a full throttle signal. At worst, just get a TPS from another car that does provide the right type of throttle signal.
I think it wants an RPM signal, taken from the -COIL.
