Bernardd Posted June 4, 2003 Author Share Posted June 4, 2003 I haven't actually run my car with the megasquirt/spark ecu's yet but it should work. The cas sends out a 0-5 volt square signal per cylinder. That's what mspark wants to see. Bernardd Quote Link to comment Share on other sites More sharing options...
pparaska Posted June 5, 2003 Share Posted June 5, 2003 Megatweak http://members.shaw.ca/megasquirt/manual/mtune.htm (software) does automagic VE table tweeking of the Megasquirt based on O2 sensor output. I believe someone has implimented that with a DIY WBO2 to be able to have differing air/fuel ratios in the VE map that it would target. Quote Link to comment Share on other sites More sharing options...
Bernardd Posted July 11, 2003 Author Share Posted July 11, 2003 Now they've got Megasquirt'N'Megaspark in one. This is what I've been waiting for over a year. As soon as the code is made available I'm in. Bernard Quote Link to comment Share on other sites More sharing options...
pparaska Posted July 11, 2003 Share Posted July 11, 2003 UltraMegaSquirt, I presume? I remember they were working on that. Glad it's ready. And I'm just now working on hooking my MS to my Holley Pro-jection harness...I see an upgrade coming! Quote Link to comment Share on other sites More sharing options...
Bernardd Posted July 11, 2003 Author Share Posted July 11, 2003 It uses the output for the fast idle to trigger the coil. It's the squirt box with slightly different code. No need for two boxes now or any ford ignition parts. Quote Link to comment Share on other sites More sharing options...
Mudge Posted July 12, 2003 Share Posted July 12, 2003 Sounds good, I have the Ford EDIS stuff but would not mind something easier to deal with. Quote Link to comment Share on other sites More sharing options...
Bernardd Posted July 13, 2003 Author Share Posted July 13, 2003 Perhaps I spoke too soon. The new code for megasquirtnspark doesn't have any dwell calculations in it. Your supposed to a saab ignition module with it. It may well work with NA distributor as well. It must have the dwell built into the module as timing isn't run by ecu. Bernard Quote Link to comment Share on other sites More sharing options...
Guest zline Posted July 13, 2003 Share Posted July 13, 2003 that kind of defeats the purpose doesnt it? Quote Link to comment Share on other sites More sharing options...
