Guest LT-1 350Z Posted March 24, 2002 Share Posted March 24, 2002 My car is finally ready for my first cruise after 3 years.and i,m planing to make it faster my combo is 93 corvette LT-1,msa mount kit,1 3/4 s&s long headers,2 1/2 exaust to single 3 inch thru a ultraflo mufler,custom ram air from the grill,corvette 4l60 trans,pro rachet shifter ,hypertech chip, painless wire harness with 93 speed & density computer,stock rear end with 3.54 gears.need advise in achiving 450hp on motor .I was planning on the LT-4 hot cam kit(cam,heads,intake&roller rockers)they told me is like 2,000 dollar. but i can't find were to buy it if someone can give me some advise will be appreciate. thank Quote Link to comment Share on other sites More sharing options...
Mike C Posted March 24, 2002 Share Posted March 24, 2002 You can buy it through GM. Check out Scoggin Dickey or Jim Pace.You could also have your existing heads CNC ported and buy an aftermarket cam. Quote Link to comment Share on other sites More sharing options...
Guest LT-1 350Z Posted March 24, 2002 Share Posted March 24, 2002 Thank mike i'm going to check those site right now. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted March 25, 2002 Share Posted March 25, 2002 first thing is that AFR makes a much better flowing set of heads for that LT1 than chevy does and the HOT CAM is not the best choice , crane makes some better choices, call them. http://www.airflowresearch.com/ http://www.cranecams.com/camshafts.htm Quote Link to comment Share on other sites More sharing options...
Guest LT-1 350Z Posted March 25, 2002 Share Posted March 25, 2002 thanks for the help your info is helping me to choose the combo i need to make my car faster.grumpyvette i see that you have 92&96 corvette modified so you know the lt-1 engine.I had build 94 vette with lingerfelter cam,arizona speed & marine heads,58mm throttle body,1.6roller rocker.Three different places program the computer and super chips finally got it right.I don't need that headache anymore Quote Link to comment Share on other sites More sharing options...
Guest super280z Posted March 25, 2002 Share Posted March 25, 2002 you want 450 at the wheels or at the crank? if you've built LT1's before you know that a decent set of ported heads and a cc306 will do 450 and then some at the crank and retain a decent driveability. i'd definately stray from the hotcam stuff like grumpy said. thats stuff is geared more towards driveability and meeting emissions requirements than towards power. if it's at the wheels, look at a 383-401 ci combo, w/ afr's and a solid roller. Quote Link to comment Share on other sites More sharing options...
