turbo interchangeability
Guest Betzeralli
Guest Betzeralli
I need some real deal Z Boys to set me straight on a few things.
I have a 78 z. I'm swaping in an '81 turbo. I don't have the engine wiring harness for the '81 turbo. I DO have a distributer (with dist. shaft), ecm, wiring harness, coil, from an '82 turbo. Can i use the electronics from the 82 turbo on my 81 turbo, including i switch the distributer and shaft, and coil? Am i missing anything?Will the 81 injectors work with the 82 electonics?
Please guys you have always come through! :roll: !
The injectors would work fine, they are the same.
You have the ECU and wiring for the 82 though? So sounds like you are set to me, I'm sure someone will chime in with anything I may have missed though.
Put in the 82 diz and I think your set.
youre fine, 82 harness plugs right in, just eliminate the external CAS on 81 motor so you dont end up troubleshooting something that doesnt do anything in this setup, and remember there are no resistors inline to fire the injectors. let er rip.
