Guest thepenguin99 Posted April 23, 2003 Share Posted April 23, 2003 Ok my wheel is sitting out about an inch more at the bottom than at the top. I got around to checking different things and I am starting to wonder what the heck is up. The ball joint and control arm bushing seem to both be in good shape. My car has no evidence of ever being involved in a serious accident. I am now thinking that maybe the spindle is bent. Am I totally off my rocker? My first thought was that the strut tube was possably bent but I would think I could tell if that was the case whenever I went over a bump. Please help. This problem is really getting annoying. Nathan Quote Link to comment Share on other sites More sharing options...
Mudge Posted April 24, 2003 Share Posted April 24, 2003 Sounds like what you are talking about is negative camber, does that sound right? I have too much on my rear setup and the tire wears poorly, drivers side is a tad lower also but the springs are cut so that could be why. How low is the car? Quote Link to comment Share on other sites More sharing options...
Guest thepenguin99 Posted April 24, 2003 Share Posted April 24, 2003 My car is stock ride height I think so I dont think it has to do with the springs or ride height. Quote Link to comment Share on other sites More sharing options...
j260z Posted April 24, 2003 Share Posted April 24, 2003 have you checked the wheel bearings? or maybe a broken shock? Quote Link to comment Share on other sites More sharing options...
Guest thepenguin99 Posted April 24, 2003 Share Posted April 24, 2003 The wheel bearings feal a little slack, I can shimmy the wheel a little when it is jacked up. Do you think that could cause the wheel to be out a full inch at the bottom? Nathan Quote Link to comment Share on other sites More sharing options...
j260z Posted April 24, 2003 Share Posted April 24, 2003 i'm not sure, but if there is any slack in the wheel it is not a good sign. it could be that the little slack that is there is enought that, over the 24" or so diameter of your wheel, it could make the wheel look like it is out by an inch. i would definately adjust the tension on your bearings and replace them if needed. they don't cost that much. i think i paid $25 canadian for the inner, outer and seal. Quote Link to comment Share on other sites More sharing options...
Mudge Posted April 24, 2003 Share Posted April 24, 2003 If the bearings are moveable at all they are shot. Quote Link to comment Share on other sites More sharing options...
Guest thepenguin99 Posted April 24, 2003 Share Posted April 24, 2003 Well new wheel bearings here I come then probably=). Does me being to slightly shake the wheel indicate that they are totally bad or do I need to take it apart and examine them? I hope this fixes the problem because its the only thing keeping me from driving my car. Quote Link to comment Share on other sites More sharing options...
jt1 Posted April 24, 2003 Share Posted April 24, 2003 No way a little wear in the wheel brgs is gonna give you 1" difference between the top and bottom of the tire unless they are so loose the hub is about to fall off. I'd guess a bent strut, bent strut tube, shot lower ball joint, bad LCA bushing, or frame damage from a wreck. John Quote Link to comment Share on other sites More sharing options...
Guest thepenguin99 Posted April 24, 2003 Share Posted April 24, 2003 Well I tightened up the bearings today and it got rid of the play in the wheel. My wheel still sits an inch or so out at the bottom grrrrr. I guess I will change the spindle tomarrow just to see if it helps. doh Nathan Quote Link to comment Share on other sites More sharing options...
Mudge Posted April 24, 2003 Share Posted April 24, 2003 Yeah, it wont account for an entire inch (have you checked your springs?), but if you can move them any noticeable amount they are dead and will get worse fast. Is there nothing obviously wrong with the half shafts when looking at the rear end? I would think something would have to be pretty whack, either springs or something busted, or A arm stuff coming off the car litterally. Quote Link to comment Share on other sites More sharing options...
Guest thepenguin99 Posted April 25, 2003 Share Posted April 25, 2003 Thx for all the input guys. Today I switched the strut tube/spindle from my parts car and it fixed the problem. The odd thing is you cannot tell the old one was bad by looking at it or using a straight edge on the tube. woohoo almost driving again Nathan Quote Link to comment Share on other sites More sharing options...
