fuel cell loose?
stony
Is it plastic or aluminum cell? If plastic, it should have 4 parts to the brackets. Two U shaped pieces that cradel the cell and two flat bars that run across the top to "lock" the cell in place. Hope that helps. Mark
Cell should be vented to the atmosphere so I doubt it is loose for expansion. Sounds like a call to summit is in order. Maybe some wrong bracket pieces were sent out with your cell? Mark
