zgeezer Posted May 15, 2003 Share Posted May 15, 2003 A few months ago there was a post related to an really good LT-1 site that had just about everything on it. I've tried to locate it using our search function for LT-1.* and every other variation I can think of. I get a little of 600+ hits on LT1. I'm lost. Can anyone help. gw Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted May 15, 2003 Share Posted May 15, 2003 Is this it? http://csce.uark.edu/~jgbertr/rb/4th_gen_tech1.html Bookmark Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted May 15, 2003 Share Posted May 15, 2003 more info http://www.corvetteactioncenter.com/specs/1996/96technology.html A bolt on LT4 performance upgrade for your LT1. The > LT4 conversion kit includes parts needed to change > the > top end of the LT1 to LT4 specs. Conversion kit > includes: 2 Cylinder Heads P/N 12363287, 1 Intake > Manifold P/N 12550630, 1 GM Performance Parts LT4 > Hot > Cam P/N 24502586, 1 1.6:1 Aluminum Roller Rocker Arm > kit P/N 12370839, 2 Head Gaskets P/N 12551488, 2 > Intake Gaskets P/N 12367777, 1 Front Timing Cover > Gasket P/N 10128293, 1 Water Pump Seal P/N 10217886, > 1 > Front Crankshaft Seal P/N 10128316, 1 Oil Pan Gasket > P/N 10108676, 2 Valve Cover Gaskets P/N 10108625, 2 > Exhaust Gaskets P/N 12552470. Also includes: 1 > Distributor Seal(1995-1997 cars) P/N 12552428, and 1 > Distributor Seal (1992-1994 cars) P/N 10128317, but > only one of these is used depending on apllication. > Not included in the kit, but recommended is the > "Extreme Duty LT1/LT4" timing chain kit P/N > 12370835 http://www.malcams.com/legacy/misc/headflow.htm http://www.malcams.com/legacy/misc/lt1lt4.html http://www.protechmachine.net/lt4/lt4.html http://www.corvetteactioncenter.com/specs/1996/lt1lt4.html http://www.afrashteh.com/guide/install.htm http://www.automotiverebuilder.com/ar/ar99928.htm http://phil.tobin.net/Hoover/index.html http://csce.uark.edu/~jgbertr/rb/4th_gen_tech1.html http://www.idavette.net/winback/lt115.htm http://www.armory.com/~greymage/resume/lt1.html http://home.tir.com/~steveher/lt4.html http://www.lt1intake.com http://www.kendrick-auto.com/lt_1__gm_head.htm http://www.protechmachine.net/lt4/lt4.html http://www.automotiverebuilder.com/ar/ar99928.htm LT1 http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=738&pid=2587 LT4 http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=738&pid=2588 More links: http://www.chevytalk.org/forums/Forum64/HTML/006238.html http://www.chevytalk.org/forums/Forum64/HTML/012593.html Opti Spark link: read http://www.charm.net/~mchaney/optisprk/optisprk.htm http://www.fierolt1.com/lt1_95_up_OptiReplace.htm http://www.noid.org/~muttvette/opti.html http://www.gulicks.com/vette/projects/opti/index.html http://www.houston-f-body.org/tech/optispark/ http://www.dynotech-eng.com/dynaspark.htm http://www.corvetteclinicinc.com http://www.corvettefever.com/howto/16758 Quote Link to comment Share on other sites More sharing options...
niceguy678us Posted May 15, 2003 Share Posted May 15, 2003 damn grumpy,.......................good job Quote Link to comment Share on other sites More sharing options...
Guest gprix1 Posted May 16, 2003 Share Posted May 16, 2003 He's the LINK MASTER!!!! Quote Link to comment Share on other sites More sharing options...
