z31 clutch same as rb26 clutch?
stony
Hey i remember someone was talking a z32 clutch was the same spline count as the rb26 but i cant find it anymore. Anyone have there clutch accessable to see if the z32 clutch will fit?
i want to be able to use a cheaper replacement clutch till i can get my hands on a twin plate.
removed the tranny tonight and looked at the clutch. it was the worst smelling car part i have ever delt with. next to burnt diff oil it is the worst. at any rate the clutch is done. I am so fricken close to getting an adapter and going auto. powerglide maybe. :roll:
Guest FullBoostOrBust
This is a very good topic, We need to find a hybrid clutch for the RB tranny. Spending $2000 US on a clutch / flywheel assem is not something i want to be hit with down the road.
What I gathered from 300zxclub.com and twinturbo.net is that Z32 clutch will fit RB26 but not the flywheel. Z32 flywheel has 8 bolts while RB26 takes only 6 bolts.
-Guycali
Guest 1SickZ
non-turbo will fit and were not talking about pressure plate bolts were talking flywheel to crank bolts.. rb being 6 like Z31 and Z32's are 8
so im thinkin a 88+ Z31 clutch will do the job along with a 88+Z31 flywheel.
Guest das280zx
what about an L28 clutch? They are six bolt. 240mm for the 2+2 and turbo flywheel. Hmm is rb really a derivative of the L-series? maybe. Also check out 240sx clutch. Maybe too small, but high perf. clutches should be avail. Getting starter to work may be a major b!tch!
Guest tx84ae
Dood automatic is for old ladies. Never swap from a manual ! get a better clutch.
I suppose that's why all the really fast cars use them, right. :roll:
Auto + turbo = no boost loss on shifts ;)
