Guest Vince Posted June 10, 2003 Share Posted June 10, 2003 Well it was half off day at the local "pick a part".....and to make a long story short i came home with a rajay turbo that i plucked from a modified 240z. The problem i'm having is identifying the details about the turbo. Im a newbie to turbos so bear with me. Are there any sites with listings of model numbers for turbos or anything like that? The model number is 3aa1ee60b1. It was a carbureted draw through setup by the way...which seems odd to me. I also took the intake manifold which i also cant identify, im new to L series engines as well. The manifold says "Turbo Z" , im guessing its a stock piece? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Mike C Posted June 10, 2003 Share Posted June 10, 2003 Sounds like the turbo toms setup. I trust you got the exhaust manifold? It is the most important probably. I think that setup used the SU carbs mounted side by side facing forward? Quote Link to comment Share on other sites More sharing options...
Guest Vince Posted June 10, 2003 Share Posted June 10, 2003 Im not so sure it was a kit. It looked fabricated. The exhaust header was quite beat up, and i could see where they plugged up the holes which were originally used for emissions equipment. Also it looks like there was a holley 4 barrel carb on it, which was gone when i got there but i was able to get the part that adapted it to the turbo. I'll get pics soon... Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted June 10, 2003 Share Posted June 10, 2003 Thats cool old school stuff, the Rajay is pretty much junk but the adapter is cool and you should get the manifold just because it is set up with a TO4 flange. Try to take some digital pics of the turbo and I can tell you what it is more or less. I would bet it has a large exhaust wheel and small compressor.... Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted June 10, 2003 Share Posted June 10, 2003 Yes and it will be a slow spooling pig too. I had a Rayjay on my car from the old BAE set-ups, and man that sucker spooled slow. It made some power when it came up, but it was like you are five and waiting for Christmas all over again. It takes forever. Be cool to play with it and see what you could get it to do. With a holley on there, you could stick a plate system under there and really give it a boost, or make it go BOOM. Quote Link to comment Share on other sites More sharing options...
Guest shuyun Posted August 4, 2003 Share Posted August 4, 2003 Did it look like this?http://www.hybridz.org/phpBB2/album_personal.php?user_id=2681 I can give you some info about the setup. Quote Link to comment Share on other sites More sharing options...
Guest Vince Posted August 4, 2003 Share Posted August 4, 2003 Quote Did it look like this?http://www.hybridz.org/phpBB2/album_personal.php?user_id=2681 The setup was similar to that, but its not the same one. I have since sold the turbo and carb adapter, though i still have the intake manifold. I uploaded a pic of it in my gallery http://www.hybridz.org/phpBB2/album_pic.php?pic_id=1458 Quote Link to comment Share on other sites More sharing options...
