Heavy Z Posted June 12, 2003 Share Posted June 12, 2003 My 650dp likes to try and stall my car under hard braking, my carb shop said DP's do that - any cures aside from a different carb? Thanks Quote Link to comment Share on other sites More sharing options...
David K Posted June 12, 2003 Share Posted June 12, 2003 My 650dp likes to try and stall my car under hard braking' date=' my carb shop said DP's do that - any cures aside from a different carb? Thanks[/quote'] I dont know anything about carbs....well maybe SU's.....but maybe you can make some sort of baffle in the resevoir(s)? Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted June 13, 2003 Share Posted June 13, 2003 You might want to try a bowl vent baffle. It would help control fuel slosh under high g-forces. http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=739&prmenbr=361 Quote Link to comment Share on other sites More sharing options...
Mike C Posted June 13, 2003 Share Posted June 13, 2003 The other guys are on the right track. Try lowering the float level in the rear bowl, most likely it is surging out of the vent and into the motor causing the bog. An offroaders trick is to put a piece of short hose from one bowl vent to the other, then at the peak of the hose, shave off about an inch wide strip opening up the hose to atmospere. Looks like a "U" with a flat bottom where it was shave, turned upside down. Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted June 13, 2003 Author Share Posted June 13, 2003 Once again, thanks for the help. YOU GUYS HAVE REALLY BEEN HELPFUL IN GETTING MY Z RUNNING BETTER - MUCH APPRECIATED!! Quote Link to comment Share on other sites More sharing options...
