CUBAN Posted June 12, 2003 Share Posted June 12, 2003 MY 1981 DATSUN/NISSAN 280ZX WONT START. ME AND MY DAD HAVE TRIED BUT THE CAR JUST CAUGHT ON FIRE UNDER NEATH AND NOTHING WAS BURNED. SO WHY WON'T IT START? THANKS ALEX Quote Link to comment Share on other sites More sharing options...
David K Posted June 12, 2003 Share Posted June 12, 2003 Maybe ruined some of the fuel lines? Lucky the sucker didnt blow up on ya. What side did it catch fire on? You need to provide way more info so we can help answer your questions Quote Link to comment Share on other sites More sharing options...
CUBAN Posted June 13, 2003 Author Share Posted June 13, 2003 IT WAS UNDERNEATH THE CAR THAT IT CAUGHT ON FIRE. I THINK IT WAS BECAUSE MY GRANDPA TRYED TO TURN IT ON AND KEEP GIVING IT GAS AND TURNING THE KEY AND IT STARTED TO SMOKE UNDERNEATH SO I USED A FIRE EX. TO PUT IT OUT THANKS ALEX Quote Link to comment Share on other sites More sharing options...
Tim240z Posted June 13, 2003 Share Posted June 13, 2003 Alex, you didn't get the subtle hint kindly provided by Dave above. TURN OFF THE CAPS LOCK. IT LOOKS LIKE YOU'RE SHOUTING. Thanks, Tim Quote Link to comment Share on other sites More sharing options...
David K Posted June 13, 2003 Share Posted June 13, 2003 I think your starter is toast. If you keep cranking, and cranking, and cranking, like you mentioned, then you can, and will burn the starter. Ive had smoke from mine at times. Quote Link to comment Share on other sites More sharing options...
CUBAN Posted June 13, 2003 Author Share Posted June 13, 2003 is there any way of testing the starter to see if i need a new one without having to buy a new starter. how long will a starter last from factory? its still the same one it came with out of the factory thanks alex Quote Link to comment Share on other sites More sharing options...
Guest timhypo Posted June 15, 2003 Share Posted June 15, 2003 Even though your symptoms don't really seem to me to point to a starter, if you pull a starter and take it to your neighborhood Autozone or Pepboys they'll test it for free. I would start troubleshooting by pulling a spark plug and hanging it about 1/4" from the valve cover by the wire. Have someone turn the engine over (don't touch the sparkplug or you'll get shocked) and see if a spark jumps from the sparkplug to the valve cover. If you see the spark when they turn the engine over, you *prolly* have a fuel delivery problem. Did the car run recently? Quote Link to comment Share on other sites More sharing options...
CUBAN Posted June 16, 2003 Author Share Posted June 16, 2003 Even though your symptoms don't really seem to me to point to a starter' date=' if you pull a starter and take it to your neighborhood Autozone or Pepboys they'll test it for free. I would start troubleshooting by pulling a spark plug and hanging it about 1/4" from the valve cover by the wire. Have someone turn the engine over (don't touch the sparkplug or you'll get shocked) and see if a spark jumps from the sparkplug to the valve cover. If you see the spark when they turn the engine over, you *prolly* have a fuel delivery problem. Did the car run recently?[/quote'] it ran a couple months before that and we had a tune up done, a new clucth installed, and it was working but then not even a week later it wouldn't start and it was the alteraner so we put a new one, but it still wouldn't start and we found out it was the battery but when my dad would be driving it would just stop and he would have to keep turning it back on thanks alex Quote Link to comment Share on other sites More sharing options...
Guest bobnagga Posted June 22, 2003 Share Posted June 22, 2003 so then its not the starter. check the throttle and idle air assembly. CHeck the timing. Make sure that the plug wires are on right... stuff like that. Quote Link to comment Share on other sites More sharing options...
CUBAN Posted June 22, 2003 Author Share Posted June 22, 2003 thanks for your help i try the stuff you guys said today or next weekend thanks alex Quote Link to comment Share on other sites More sharing options...
