Walbro GSL-392 fuel pump?
Guest mck2
I bought the GSL 392 with the install kit from "importpower" a few weeks back. Cost total of $135 delivered. So $100 with fittings delivered sounds like a good deal if you can get it for that.
It mounted up fine except on the intake side I needed to buy a 90 degree bend brass fitting and on the outlet needed a 45 degree bend brass fitting (nether was included). I don't have fuel pump fade using my 370's at 12 psi so upped the boost to around 15psi runs good with 93 octane. Could possibly go higher.
