Guest Spider Posted June 15, 2003 Share Posted June 15, 2003 I just need to know if I put the ECU and AFM from an 83 280zx into my 82 280zx if it will work properly or if there are going to be any problems.....also if the conversion works from a 79 zx to an 82 zx. thanx Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted June 15, 2003 Share Posted June 15, 2003 As long as they are both n/a or both turbo, you should be ok. Quote Link to comment Share on other sites More sharing options...
Guest Spider Posted June 17, 2003 Share Posted June 17, 2003 so does the AFM and the ECU have to match eachother? Quote Link to comment Share on other sites More sharing options...
Guest bobnagga Posted June 22, 2003 Share Posted June 22, 2003 yeah. the turbos match the turbos, and the nonturbos match the nonturbos. The wiring harness is different between the two as well. Quote Link to comment Share on other sites More sharing options...
zxgts-4 Posted June 23, 2003 Share Posted June 23, 2003 All the service manual states is not to mix and match CPUs because they may have different pin assignments, I definitely wouldn't alternate 79 with 83 and I cant see any difference in air flow meters on N/A but a turbo one would be different but someone else may know better. Neil Quote Link to comment Share on other sites More sharing options...
