mustang tubular manifolds vrs my steering shaft, who wins??
I'm pretty sure if you've read any of my posts by now you know I'm poor :x
SO this weeks question is do mustang tubular exhaust manifolds clear the steering shaft in my 280??
I know they aren;t as good as shorties but the price at the yard more than makes up for it. :)
Guest bluex_v1
this is Alsil's install...If I remember right he has the stock header at least on the driver side. He does have a mustang power steering rack too though, and I beleive that changes the angle of the steering shaft at least slightly. You might want to dig through his site and see if he had the header on before the power rack swap and to make sure he doesnt have a mid-shaft u-joint somewhere...
http://zcar.netdojo.com
  • 1 month later...
Guest bluex_v1
I can tell you that BBK equal length shorties definitely do not fit, and the u-joint angles would be very extreme if you had one mid-shaft. Also the flange for the down tube is at an angle that would put the pipe through the firewall unless you had the engine mounted a little further forward than ideal.
Stock - type shorty headers won't work on a Z, unless you have the engine mounted in SCCAMike's position...which is a few inches lower than mine. the collectors hit the frame rails on both sides, by about 1/4" or so. I used a block hugger on one side, and a HIGHLY modified tubluar shorty on the driver's side....pretty much for steering shaft clearence. If I had it to do over I would just put a U-joint in the shaft and use the block hugger.
I would think the stock steering shaft might work ok with a hugger, has anyone tried it?
Al
Guest bluex_v1
Stock steering shaft inteferes with both flowtech blockhuggers and patriot 'tight tuck' headers, with my positioning. Patriot ones were very close and might fit with the motor up an inch higher or so from where I had it, but I was rather unimpressed with the tight angles right off the exhaust ports. Probably would be just fine for a stock motor though.
1/4" does not sound all that bad, as long as its not in the motor mount area - it sounds like something I can cut into and re-weld? It would be rather nice to at least have shorties, or workable block huggers with a 1 5/8" primary, I am not going to be happy with 225 HP forever :)
