Use Tire Foam Under the hood
TomoHawk
I was thinking of stuff to use under the hood to clean off the gunk & protect what paint there is under there, and I saw my can of tire foam on the shelf!
I just foamed it onto the painted areas, let it sit a couple, and then wipe off the dirt & shine it up a little. Got some on the wires & hoses, but it should do them a little good too, because it's supposed to (moisturize?), clean and protect rubber stuff by design.
After treatment, I let it dry up a while to eliminate fire hazard.
I suppose any foaming stuff that "goes away" would work, but the tire foam also leaves a protective coating and cleans and treats the wires and rubber hoses too. Like putting Amour-All on after you clean. t's why I used it.
Guest ON3GO
dont use armor all on ur dash! bad for it, it can cause the dash to crack and etc... i never use armor all on anything plastic on the interior that the sun can hit
