exhaust on chevy
I dont know about the right hand drive but if they are the Hedmans that have the 4 into 1 design I think they should work. I really like the way they are made. I have not seen them on a Z but they look like they stick to the block a little better than hookers and some of the others that work.
I'm thinking if you reverse the spacers that JTR has on the setback plates and put the thicker one on the opposite side JTR shows, it should all be the same then I think? Therefore the heddman headers should probably fit.
Regards,
Lone
Lone,
When I originally put my V8 in for the first trial fit, I had mistakenly put the spacers on the wrong side. I make the motor sit at a wierd angle, so that the carb is not at all level, so I don't think that would work well.
Tim
