Guest FinalRights Posted July 4, 2003 Share Posted July 4, 2003 I'm looking for the best engine,that is also easy to mantain and install. I need to know a ball park price,hp,displacement,torque,etc. Also,how easy it is to install. Thanks. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 4, 2003 Share Posted July 4, 2003 Please use the search function. Also, instead of posting single questions in specific forums, you would likely do better by posting a general question in a non-specific forum. It appears that you have no direction here and are grasping at ideas. Please use the search function first. When you have exhausted that avenue, then ask some specifics. Please feel welcome here at HybridZ, but remember, most questions have been asked and answered many, many times before, and if they haven't, then you're probably forging new territory.... Thanks, Tim Quote Link to comment Share on other sites More sharing options...
Guest FinalRights Posted July 4, 2003 Share Posted July 4, 2003 So where should a question such as this one be placed? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 4, 2003 Share Posted July 4, 2003 Maybe Misc. Tech?, or High Tech?, or even anouncements. A more appropriate post would include what you want out of the car, you personal technical skill, you budget (time and $$), and your predefined preferences. Tim Quote Link to comment Share on other sites More sharing options...
Guest FinalRights Posted July 4, 2003 Share Posted July 4, 2003 Ok. I'd like to keep the car street legal,running low 11's/high 10's. I'd like to keep the 6 cyl set-up,maybe with twin turbos. I don't want a v8,because of weight consurns. I really don't want to do to much as far as custom goes. I can do just about anything,as long as I have instructions on doing it. Detailed instructions,and I can do it. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted July 4, 2003 Share Posted July 4, 2003 Ok. I'd like to keep the car street legal,running low 11's/high 10's. I'd like to keep the 6 cyl set-up,maybe with twin turbos. I don't want a v8,because of weight consurns. If you go with an LS1 you wont have to worry about weight...in fact with the LS1 in a 280Z(Phantom's car! ) It actually weights a little bit less than stock! Now if you want to run 10's/11's you could supercharge the LS1 and get some decent size tires in the rear and it would probably put you in the 10's for sure!!! I think that would be very streetable. But again your talking some serious money here. Also there arent step-by-step directions for everything with this swap but there is a "swap manual" made by JTR(Jaguars That Run) Use the search function and you will know what I am talking about. Whats the budget on this? Guy Quote Link to comment Share on other sites More sharing options...
Guest FinalRights Posted July 4, 2003 Share Posted July 4, 2003 The budget will change depending on how much I work : . I get paid better when I make more sales,so I'll probably push myself even more once I get an engine set in my mind. Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted July 4, 2003 Share Posted July 4, 2003 Hands down Ls1 and super charge it, that is if you have the bucks . High 10's low 11's would not be a problem. Mike Quote Link to comment Share on other sites More sharing options...
Guest Zachb55 Posted July 4, 2003 Share Posted July 4, 2003 And if you wanted to stay 6cyl and keep it in the fam. you could go RB26. BUT, to get into the tens you will likely spend close to 20 grand on the swap and to keep from turning your car into a twisted pile of metal once that 400+ hp hits the ground... If you have the money, do whatever you think is the coolest, i guess that is all it comes down to really, do you like superchargers or turbochargers? big blocks, small blocks, inlines, rotary, 4 banger? if you think you can do something, you can definately give it a whirl. a lot of swaps though you'll have no guidance, the SBC would be by far the most documented, and the RB for the inline family... -Zach Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 8, 2003 Share Posted July 8, 2003 How about this engine? http://www.lingenfelter.com/pac725ttls1y.asp For that price, it had better come with a 2 year/24,000 mile warranty! Personally, I wouldn't do an RB. The only one of the series worth messing with is the RB26DETT, but that is not going to fit in the Z31 without a lot of modification. And like Zach said, it's going to be expensive. It is a good thing that you can follow instructions. But unfortunately, that is not going to help you to swap an engine into a car that it wasn't made for. I don't mean to sound like a pessimist, but when you are doing custom modifications, there are TONS of little problems that just pop up, and you have got to be able to hand them, or you're not going to finish it. I own an 84 non-turbo 2 seater. These engines, while almost 20 years old, are still very good engines. There are Z owners on z31.com pushing over 500 hp with these engines. My recommendations? Buy a turbo z, or swap in a z31 turbo engine, OR just swap the turbo components (see z31.com). On the other hand... If I didn't believe in swapping foreign engines into Z's, I wouldn't be on this forum. If you think you are really up to the swap, I say go for the gusto. LS1 with a turbo, hell ya. Or even an LT1 for that matter, as long as you use a turbo! (or you could take these guys suggestion and go with a blower-wouldn't have to worry about the exhaust manifolds. But what fun is that? Quote Link to comment Share on other sites More sharing options...
tjcannon Posted July 8, 2003 Share Posted July 8, 2003 Easy to maintain? Easy to install? NO ELECTRONICS!!! I'm putting a small block chevy 350 into an 88 turbo right now. Holley 650CFM Carb. GM 700R4 Tranny. All I gotta worry about is fuel, throttle, and kickdown cable, and it'll be running. Oh, I also agree that being able to follow instructions will get you NOWHERE in swapping a motor. If you're planning on dropping a chevy engine in there, there are VERY few people who have done it before to the Z31. No one's gonna be there to answer your question about oil pan clearances around the steering, or anything else you might run across. Good luck with your swap, whatever you decide to put in it. Quote Link to comment Share on other sites More sharing options...
