turbos' ive found....
Guest ON3GO
Guest ON3GO
hey guys,
sense im gonna be upgrading the turbo and etc on the L28ET right away i have been looking around.
looking for 350+rwhp on pump gas, nothing real laggy.
i found this.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2422341962&category=33742
also what A/R intake and A/R exhaust am i looking for on a turbo for my setup?
and i as talking to my buick t-type buddy and he said to look into a turbo called TE-44, he said its used on GN's and its a great turbo.. anybody on here ever use on or no's about it?
also found this.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2422297051&category=33742
as you can see im on a tight budget.
thanks
Guest ON3GO
Go to the Turbonetics web site and do a little research on compressor maps. If you want a T3/4 you can get new T04B's (V or H) for $400 and E's for $450 ( 57 or 60). Either will easily make 350 rwhp. Then just swap out your turbine, turbine heat sheild and housing and you have a nearly new turbo that will bolt up. Or just buy what you need if your center section is fairly fresh. Alot of the Ebay stuff won't bolt up. Lag goes along with having a turbo. Unless you are going Full T4, P or Q trim and larger than .81 I wouldn't worry about lag. Any T3/4 will spool fast enough.
hey guys' date='
(1) http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2422341962&category=33742
al
(2) http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2422297051&category=33742
thanks[/quote']
On turbo 1, it is hard to tell if it has a t3 flange on the exhaust or a T4, but it does have an 11 balde turbine wheel that looks kinda small, and you will need an external wastegate to make it work. If you are on a budget, maybe you should look at something else.
On turbo 2, it looks small by the pics, but may work. I don't have much info on IHI, and you would need to know what the wheels are to be sure it is adequate.
Personally, I would not buy a turbo from someone unless they could tell me specifically what wheels were in it, and what size the housings are.
Turbo 1 will require an external wastegate.
Turbo 2 is a t4 flange, which will require machine work to weld a flange to the factory exhaust manifold, and an external wastegate.
Turbo 3 will bolt right up, you cab get a flange for the exhaust anywhere, and fab up a 3 inch exhaust. It will not connect to the Nissan downpipe.
The intercooler is nice, but very wide, make sure you won't have fitment issue's before bidding.
