350 TPI
the MOST the stock TPI came with factory rated was 245hp
first year
http://www.rogerscorvette.com/specs/85.htm
last year
http://www.netvettes.com/1991.html
with port work you can get in the low 300 hp range BUT ITS BASICALLY A WASTE OF TIME AND MONEY,it only flows about 200cfm stock and fully ported flows about 230-240cfm
READ THIS
http://www.eecis.udel.edu/~davis/z28/winter01/dyno/dyno021105/webpage021105.html
heres a custom lowered version of the stealth ram efi that MAKES AN EASY 30-90 hp more than a TPI (DEPENDS ON ENGINE COMBO)with more than 1" more hood clearance
http://fasterdeals.com/vette/index.html
IT FLOWS ABOUT 275cfm OUT OF THE BOX AND PORTED FLOWS ABOUT 300CFM,THATS A HUGE IMPROVEMENT WORTH EASILY MEASURED HP OVER ANY TPI, WITH IMPROVED HEADS AND CAM A 30-90 HP INCREASE DUE TO FAR LOWER AIRFLOW RESTRICTION IS POTENTIALLY POSSIABLE AND SEVERAL ENGINES HAVE SHOWN 60-80 HP IMPROVEMENTS WITH MILD MODS
heres the holley standard version (JUST OVER 10" tall)
the one i am picking up is from an Iroc-Z camero
and if i can get 300hp i'll be happy.
a friend of mine seemed to think they stocked between 250-300hp
and i think i'm going to try and stick it in a nissan 2wd d21 hard body
i would do the z conversion.
to be truthfully honest. i live in maine and alot of salt is used on the roads. and i do not own a garage to store it in.
i have one of those portable garages and i built a wood platform last summer so could work on my vehicles.
and i think if i had a z it would have to be stored winters. and i just can't cut that.
but 2wd d21's are a dime a dozen! so if i leave it out side i won't feel bad.
and the full length frame is always a plus too.
