280Zen Posted July 10, 2003 Share Posted July 10, 2003 Ok, it may be a dumb question, but I know there is not a oil temperature switch on the 280zx NA but there is one on the 280zx Turbo models. Where is it located? neither haynes or chiltons even mentions it. I see it on the wiring diagram, but don't know where the sensor is located at? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted July 10, 2003 Share Posted July 10, 2003 It's not a switch, but a sender for the gauge. It's located on the oil pan near the drain plug. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted July 10, 2003 Share Posted July 10, 2003 Thats where it is... Anyone ever mapped one out? I't would be an interesting feature to add sometime. Quote Link to comment Share on other sites More sharing options...
280Zen Posted July 10, 2003 Author Share Posted July 10, 2003 Thanks, Yea I thought it was in the oil pan but none of the manuals or the Datsun service manual mentions it! so I figured Id ask. This is what Im trying to do. Use the turbo oil pressure/temp gauge and the NA volt gauge along with the digital clock on my NA 280zx. I have a turbo oil pan to use. Which brings up my next question, Is the 82/83 turbo oil pan and the NA oil pan the same other than the sensor pickups? The wiring diagrams are fairly easy to follow I know which wire goes where. This should be a fun mod. Quote Link to comment Share on other sites More sharing options...
z-ya Posted July 10, 2003 Share Posted July 10, 2003 I installed an Autometer oil temp gauge in place of my clock. I installed the Autometer sender in the factory oil temp sender. I removed the OEM sender and drilled and tapped it for 1/8" NPT. I screwed the Autometer sender into the OEM sender. Then I screwed the whole assembly back into the oil pan. It works great. The max oil temp I've seen so far is around 190 deg F. I'm am running an oil cooler. Haven't had it one the track yet though. I'll find that out in August. Pete Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted July 21, 2003 Share Posted July 21, 2003 I did the Autometer install also. I recently sacrificed my stock oil cooler for additional intercooler space and looped the oil cooler lines. On a top end run the oil temp went to 220F after less than a minute at 15 psi boost. With the cooler - it never went past 180-190F. BTW - the Z runs at 168 mph at 15psi on the radar gun. Stock body with an airdam and splitter. I think its time for some more aero tricks IMO the oil cooler is required for a turbo conversion but I wouldn't worry about an oil temp gauge if you have a cooler. Doug Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted July 21, 2003 Share Posted July 21, 2003 Doug, where did you hit 168? Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted July 22, 2003 Share Posted July 22, 2003 Hey Cody - That would be on a straight stretch of road about 10 miles from my house. I don't live anywhere near a city. Just 8 miles of straight, flat road (that was reciently paved!!). It really doesn't take that much road to wind it up anymore. Cheers - Doug Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted July 22, 2003 Share Posted July 22, 2003 How did you verify that? I'm not doughting you. Just curious? Quote Link to comment Share on other sites More sharing options...
280Zen Posted July 22, 2003 Author Share Posted July 22, 2003 How did you verify that? I'm not doughting you. Just curious? Hopefully its not one of those little yellow sheets that those friendly police are always wanting to hand out to people! Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted July 22, 2003 Share Posted July 22, 2003 Hey Cody - It was on a radar gun - not sure how accurate they are but the cops seem to think that they are - I guess that I could try the flying mile - Doug Quote Link to comment Share on other sites More sharing options...
