383 240z Posted May 8, 2002 Share Posted May 8, 2002 I have a SJ 327 sitting here it has flat tops and a set of 882 76cc 1.94 intake. I was thinking of putting it in front of a TH-700-R4 with a Holley 600cfm (vac 2ndarys) to see use as a street motor in my 73 240Z w/ 3.08 rear gear and 27" tires. Any input on a decent cam would be helpful Keith Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 8, 2002 Share Posted May 8, 2002 A Comp Cams 270 H Series (270 degrees advertised duration and 224 degrees @.050") with block hugger headers and the 600 CFM 4 barell carb with a 700R4. Quote Link to comment Share on other sites More sharing options...
383 240z Posted May 8, 2002 Author Share Posted May 8, 2002 Any hints as to the output? Keith Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 8, 2002 Share Posted May 8, 2002 Mr. Grump will have to answer on the out put. I was just looking at the cam max for steetability with 600 carb and stock torque converter. Quote Link to comment Share on other sites More sharing options...
383 240z Posted May 9, 2002 Author Share Posted May 9, 2002 I forgot to add that it is a 3000 stall 9" non-lockup converter. Keith Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted May 9, 2002 Share Posted May 9, 2002 Where did you get a 3.08 rear? I didn't realize Z rears went that low numerically. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted May 9, 2002 Share Posted May 9, 2002 if your looking for a good running cam for a 327- 350 daily driver with a few more hp than stock but still pass emissions and works with all the stock parts, may I sugguest the , http://dab7.cranecams.com/SpecCard/DisplayCatalogCard.asp?PN=114132&B1=Display+Card Quote Link to comment Share on other sites More sharing options...
383 240z Posted May 9, 2002 Author Share Posted May 9, 2002 Jim, The 3.08 is from an 82 vette (Dana 44M) Gumpy thanks for the input. Emissions are not a problem, does that change the cam recommendation at all?????? How do C4 stock exhaust headers flow? Will they work with this? And fit a Z??? Keith Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted May 10, 2002 Share Posted May 10, 2002 Keith, I had that same combo. (heads and crank) It's quite a low comp. ratio overall as I recall........if you can trade your heads for a smaller cc head it'll wake it up easier. On the other hand mine was amazingly tolerant of timing and tuning flops Quote Link to comment Share on other sites More sharing options...
