327 cam any Idea's?
I have a SJ 327 sitting here it has flat tops and a set of 882 76cc 1.94 intake. I was thinking of putting it in front of a TH-700-R4 with a Holley 600cfm (vac 2ndarys) to see use as a street motor in my 73 240Z w/ 3.08 rear gear and 27" tires. Any input on a decent cam would be helpful Keith
Guest Anonymous
A Comp Cams 270 H Series (270 degrees advertised duration and 224 degrees @.050") with block hugger headers and the 600 CFM 4 barell carb with a 700R4.
Guest Anonymous
Mr. Grump will have to answer on the out put. I was just looking at the cam max for steetability with 600 carb and stock torque converter.
Jim,
The 3.08 is from an 82 vette (Dana 44M) Gumpy thanks for the input. Emissions are not a problem, does that change the cam recommendation at all??????
How do C4 stock exhaust headers flow? Will they work with this? And fit a Z???
Keith
