JKDGabe Posted July 15, 2003 Share Posted July 15, 2003 I've got the MSA aero kit II and the side skirts don't fit quite right to the body in front of the doors. They kinda warp out leaving a gap of about 3/4". They're used... Any ideas on how to make it look good? Quote Link to comment Share on other sites More sharing options...
JKDGabe Posted July 15, 2003 Author Share Posted July 15, 2003 RacerX to the rescue! Thanks alot. I'll get pics up when I get this thing finished. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted July 22, 2003 Share Posted July 22, 2003 or you could just put a small rivet in it and hold it down. Just a thought Quote Link to comment Share on other sites More sharing options...
timh Posted July 22, 2003 Share Posted July 22, 2003 You have my sympathy. I had the same problem, so I guess you have my empathy too. If they're as bad as the two sets I returned to MSA, forget about the tape. I eventually gave up on the side skirts, the guy that did my bodywork is a perfectionist and wouldn't install them if they were going to be under that much torsion. I ended up with some urethane side skirts. They're not as custom looking, but they are much easier than the "easily installed and painted" fiberglass MSA skirts. Hope the heat trick works for you. Quote Link to comment Share on other sites More sharing options...
JKDGabe Posted July 24, 2003 Author Share Posted July 24, 2003 Yeah, the rivet idea would work if it wasn't so far off. It previously had screws but I don't like the thought of putting screws into my sheetmetal... I just patched the trim holes! I don't have a heat gun and the blowtorch scares me so think I'll leave 'em off. Anybody wanna buy a pair of side skirts? Quote Link to comment Share on other sites More sharing options...
MAYHEM Posted July 28, 2003 Share Posted July 28, 2003 you might try using automotive double-sided tape which is used for side mouldings. Very tenacious adhesion - so you'll need to very accurate when positioning the part. Also' date=' note that if you need to remove the part - you will have difficult time removing it. RacerX[/quote'] Are you refering to a 3M type products? RacerX. I went to there web site and was checking out there DST (Double Sided Tape). But also just found this too, do you have a word on this product? Duramix http://www.3m.com/us/auto_marine_aero/aad/prod_lines/duramix/duramix.jhtml I just picked up a MSA kit, and have been pondering the best way to attach it. Thanks Quote Link to comment Share on other sites More sharing options...
MAYHEM Posted July 29, 2003 Share Posted July 29, 2003 Thanks for your insight, RacerX. Below is charactics of the adhesive they (3M) suggested, to me via e-mail. You made a valid point how will I hold it in place? I guess small sheetmeatal screws would work, if out of sight. Characteristics Bonding Time Range 30 Minute Container Volume 6 Fluid Ounce (US) Cure or Dry Time 4 Hour Work Time 10 Minute Thanks again Quote Link to comment Share on other sites More sharing options...
MAYHEM Posted July 30, 2003 Share Posted July 30, 2003 I went through my tool boxes and forgot a had Panel Holding System, I got when I was in the Air Force. If you go to http://www.eastwoodco.com/ and type in Panel Holding System you will see what I mean. I think I can get it to work. Quote Link to comment Share on other sites More sharing options...
