Turbo FPR Same As NA FPR?
z-ya
All of the FPRs have manifold reference capability. The turbo and NA FPRs look identical. I have an NA one int here now, and the pressure is around 38psi (1000RPM).
I'm just wondering if the turbo FPR is a rising rate, or is it the same as the NA.
Pete
They are calibrated differently. The max psi the na regulator delivers is calibrated to occur at zero manifold pressure, while the turbo is calibrated to a positive (zero + boost psi) manifold pressure when max fuel pressure is delivered. DAW
Calibrated? If they have a vac port there's no calibration to speak of - they're 1:1 which is what you want. I've used generic "N/A" regulators on forced induction cars plenty of times - they work fine. The only time I've ever seen one specifically for forced induction is when it's being used as a "crutch" ala FMU and has a greater than 1:1 rise in fuel pressure.
It works like this - 1psi (for lack of a better term) of vac lowers fuel pressure by the same amount. 1psi of pressure raises it by the same amount. However the fueling to the injector remains the SAME. Why? Well, in vac the engine is attempting to draw fuel through the injector like soda through a straw - the fuel pressure is reduced as a result of not needing the additional pressure to inject the fuel. Under boost the opposite occurs and must be counteracted - boost is attempting to push the fuel back up the injector and into the fuel tank.
Make sense? You could certainly use an FPR with NO vac connection but this would make tuning the fuel a nightmare and under boost might push back enough that the injector wouldn't be able to provide enough fuel or distribute it correctly. This is one of the reasons I HATE FMUs - they make tuning a nightmare since you no longer know how much fuel the injector is oging to actually be spraying at any given time - even assuming the silly thing raises pressure correctly (not often).
I think DAW was referring to the difference between a rising rate (like the cartech piece) FPR for turbo vs. n/a. In this case, what he said makes sense - a rising rate FPR for a turbo would do nothing on an n/a car, since you would never get to the non-linear part.
I'm still not convinced that the RR FPRs actually do anything on n/a cars, though (i.e., I don't know if they actually calibrate them differently).
