Engine Management Question
Guest 02WRX
Guest 02WRX
hello i am currently intrested in starting a project datsun 240z. i would like to drop in a 96 or so LT1 engine and leave it fuel injected. My question is what kind of engine manegment would i need to run with this setup? Any info would help. thanks.
There are many different stand alone systems available. Search the web, and do the research. What about using the OEM computer?
I'm using a Wolf 3D computer on my turbo L28, and I had great luck with it. The SDS is also a very popular system. And don't forget electromotive. The lsit goes on and on.....
Pete
some efi companies have specific applications for lt1.easy way would be a painless harness and use a pre obd2 ecm.if you look on the chevy forums there is a software /cable kit that lets you reprogram the ecm with a laptop.i did a lt1 in a early nova and had tpis modify the ecm.the vats(anti theft) and egr systems were removed from the ecm.
Use the OEM ECU and look at something like LT1 Edit to modify the programming. In fact I think that GM may even make a harness and ECU just for swaps. Unless you're going to be heavily modifying the motor a fully programmable EMS is a waste as you'll spend a TON of time trying to get things like drivability perfect when the OEMs have already done the job for you :)
Guest z1 performance
We are an authorized Electromotive dealer, and also tune Motec, AEM, haltech and others....and are on LI, if you ever want to stop by
Adam
94-95 much easier to work with, and cheaper, as far as electronics go.
93 would be another choice, but requires PROM burning equipment, using a 94-95 harness or figuring it out yourself is possible.
96-97 is OBD II and costs $550 to program at home last time I checked, and has more diagnostics codes, including a crank position sensor which does not allow for using a double roller chain (easily), yada yada.
I own a 94, 95 is considered the "perfect year" because of these niceties.
