Guest szlash280z Posted July 28, 2003 Share Posted July 28, 2003 will a turbo's heat chew up aluminized pipes? Regular aluminized exhaust piping seems like it would be pretty skinny and not last long in a downpipe application to me. anyone ever try to use regular aluminized pipes to make a downpipe? Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted July 28, 2003 Share Posted July 28, 2003 I'll let ya know as soon as mine rust out. I think it might be awhile though. I'm sure I'll have another turbo or changed it for some other reason before I run into any corrosion proublems. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted July 29, 2003 Share Posted July 29, 2003 My DP is aluminized steel. I sprayed the high temp (1200 or 1500 I can't remember) stuff and it's staying on okay. Quote Link to comment Share on other sites More sharing options...
Guest szlash280z Posted July 29, 2003 Share Posted July 29, 2003 awesome! did you guys have a "muffler shop" make them for you? or are you welders yourselves? Quote Link to comment Share on other sites More sharing options...
yo2001 Posted July 29, 2003 Share Posted July 29, 2003 I welded mine Quote Link to comment Share on other sites More sharing options...
Guest szlash280z Posted July 29, 2003 Share Posted July 29, 2003 Hey yo2001 mandrel bent right? is it just two 45* bends? can you give me a rough idea of the length between bends? did you just weld it to the stock flange? what gauge and diameter pipe did you use? I am thinking 2.5" would be fine. I have been trying to go to welding school myself, but I have no time available for it. A guy at work said he would try to weld one together for me if I had some specs, but I have no clue how to get specs. It would probably help if I had the engine in the car... Quote Link to comment Share on other sites More sharing options...
yo2001 Posted July 29, 2003 Share Posted July 29, 2003 I got one U-bend 3 inch mandrel. I cut it in half and turned it and welded back together. I see if I can post my crappy pic. Quote Link to comment Share on other sites More sharing options...
Guest szlash280z Posted July 29, 2003 Share Posted July 29, 2003 hey, you can email me at szlash@bellsouth.net if it would be easier for you. thanks for the help man! Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted July 29, 2003 Share Posted July 29, 2003 I got aluminized too. And I welded it myself, and my welds suck, but if the pipe stays in place, I am ok with it. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 9, 2003 Share Posted September 9, 2003 yo2001, Can you let me know which sizing did you use for all the pipes? I was gonna order mine but I don't know which parts I should get. Nathan Quote Link to comment Share on other sites More sharing options...
yo2001 Posted September 9, 2003 Share Posted September 9, 2003 I used 3 inch U bends and some tight 90 deg 3inch bend. Quote Link to comment Share on other sites More sharing options...
