r-33 5speed and HKS twin plate (new) F/S
stony
Ok guys i pretty much have the rearend sold. i have decided to go with an automatic also. so some day i will be setup with a powerglide and a 8.8 ford rearend with gig axles and a spool ;>
anyways the 5 speed will pay for some of the costs for this swap. the HKS clutch is brand new and never made a run down the track. it has maybe 200 miles on it and still looks brand new. it retails for 1600 but i will sell it for what i got it for 1100. add another 800 for the tranny for a grand total of 1900 plus shipping and its yours.....BTW the clutch is complete with flywheel.
Oh no, solid rear? and what trans are you going to run??
If I did not have an O.S clutch I would get that HKS one from you.
I only made 334@ the wheels @13-14 PSI :( I was looking for more...
Good luck with your drivetrain plans.
wow dude you have alot of tuning to do;>
I made 352 at the wheels at stock booste. hows it running? does it feel good? was that just a power check or tuning time on the dyno? You should be getting alot more out of it at that PSI.
got any scans of the runs?
I am sick of driveing to the track and having to trailer it home ;< next time at teh track will be pulling the fronts off the ground :D
That is the thing we did tune it a bit on the dyno, but my altenator is not giving the fuel pump what it wants. So we tuned it a bit rich untill I get that problem solved.
The car hauls A$$ but I was thinking I should get more power on the dyno.
What A/F did you tune to on the wide band 11 to 1??
"got any scans of the runs??" I will see If I can get them from the shop
I might be at the track next weekend
depending on the dyno... should be able to email them.
here are mine the first one is a comparison of the first run on the dyno and when it was done at 9PSI
the second one is the stock booste vs 15 PSI
they were both tuned at a max 11.8 AF ratio i was having some problems picking up a timing reading so we couldnt fine tune it looks like next time its on the dyno will be with and auto solid rear setup ;>
