Help Please Z31 MAF Conversion
Guest TK240Z
Guest TK240Z
Hi, I did the 1984 Z31 MAF and the turbo ECCS into my car. I also useda 300zxt wiring harness. The sensors I have is, fuel temp sensor, maf, 300zxt o2 sensor, 1983 280zxt head temp sensor, and 280zxt knock sensor. The car doesn't run right. It won't rev. I believe I saw somewhere it stated I have to swap injector #2 and #5 wiring. Should I do it? I did ECU self diagnosis and I got only #14 speed sensor that I don't have.
any help is appreciated.
thanks in advance,
TK
For me the injector wiring swap did nothing. The firing order of the straight 6 is different than the VG, and the turbo ECU injector wiring is different too, so I doubt it'd make a difference. Can't hurt to try. If it's running and not puking any codes on you, I would say you are down to the basics - fuel pressure and spark advance.
Guest TK240Z
Thanks Sleeper,
the car is kinda running and it wouldn't rev. i haven't hooked up the tachometer yet so don't know the exactly number but i'm guessing it revs only up to like 2,000rpm.
I don't have a timing light. I'll try to lotate the distributor and see if anythingchanges.
I have adjustable fpr and I set it at 40psi.
Thanks again,
TK
Guest TK240Z
Hi,
I unplugged the maf and it was running same, so I'm in limp-mode. :cry:
Do you guys know which pins are for the maf burn-off?
I must not connected the maf wiring wrong since I used wiring harness from 300zxt. However, I wanna make sure if mine connected right.
My maf is connected as;
Red-White wire to Pin 12
Two Black wires to ground
Black-White to Pin 35(12V from EFI Relay)
Yellow-Green wire Pin 30
Gley Shileded Black wire Pin 31
Thanks,
TK
Guest TK240Z
Thanks guys, I finally got it.
It revs smoothly and makes BOOST. I have only a downpipe for now and the thing is loud. lol I haven't found out how to connect 240z stock tachometer, so I didn't rev much. It made about 6psi or so.
I've already addicted to whoosh sound that HKS blow off valve makes.
Thanks again,
TK
