question about parts on my steering rack..........
Guest ON3GO
Guest ON3GO
well im putting on my new steering boots on, and i know i need greese in there but what kind and how much is need?
also should i do anything else before hand?
thanks
mike
Near the inner tie rod there is a 1/8 inch threaded hole at the end of the rack. You can screw a grease fitting into this hole and pump some lube into the inner tie rod bearing surface.
Be sure to remove the grease fitting when you are done as it will interfere with the rack travel.
