Transmission identification?
I picked up the transmission that will be going along with the chevy 350 that I'll be getting tomorrow. I wasn't sure exactly what kind it was, other than it was "heavy duty" and "brand new". I was hoping for a 700R4, but I'm pretty sure that it isn't. I'm having trouble identifying it. All that I've found on it so far is "T5" stamped in two different places. I don't have any problem figuring out its a T5 then, but its and automatic. I was under the impression that T5 were standard transmissions, and all the info I can find online suggests the same. Is the such thing as a T5 automatic? If not, where should I look for more markings (its pretty dirty, I had to clean it off just to find the T5). Is this a decent transmission for a swap? Anywhere I can get any more info on it? Thanks..
Thanks for those links Mike C. Based on those pictures, I'm nearly positive it is a TH350. So I've got a 3 speed auto, no overdrive, however freshly rebuilt (or new, he wasn't sure which).
I'm tempted to just use the TH350, but based on other memebers experiences I think I'm going to try and find a 700-R4. I noticed one of the yards around here was having an 'any transmission you can find for $40" promotion, so maybe this is my chance to pick up a better trans cheap.
does your tranny have a vac modulater? The 350's do the pan looks VERY similar to a TH200m This is a very weak unit. you can sell the 350 for a decent price and 700's are pretty easy to rebuild. If you go junkyarding for a 700 try and find a late 87 unit these have a 30 spline converter and upgraded internals,if you are not going to use a computer to operate the TCC (ie a carbed engine) they also have a TCC shift valve Keith
Guest Want aZ
Hmmmmm ANY TRANS FOR $40?!?
Give me 3 of the T-56's Please!!!!
Will give you $500 for all 3!!!
Would be a deal at half the price@!@!!!
Damon
