mas28O Posted August 12, 2003 Share Posted August 12, 2003 I need some help on my 4l60e trans using Tunercat. I am having problems with the car hitting the rev limit before the trans shifts into the next gear. I have read that other people have the same problem when they go from 3.23 to 3.73 gears. Right now I changed the speed settings to 3.54 gears and 235/60/15 tires I also changed the speed settings on the up shift and down shift Stock the Corvette with 3.07 gears had 1>2 @ 45mph 2>3 @ 81mph 3>4 @125mph I changed these # to 1>2 @30mph 2>3 @60mph 3>4 @110 But the car still runs into the rev limit. Mike Quote Link to comment Share on other sites More sharing options...
Mudge Posted August 12, 2003 Share Posted August 12, 2003 Have you tried looking at any Hypertech files? Quote Link to comment Share on other sites More sharing options...
Lone Star 1 Posted August 12, 2003 Share Posted August 12, 2003 On the LS1 you have to set both speed and RPM of the shift, and both requirments must be met befour a shift will happen. When I had mine LS1 edited it kelp hitting the limitor, came to find out I was 2 quarts low on fluid. Quote Link to comment Share on other sites More sharing options...
mas28O Posted August 12, 2003 Author Share Posted August 12, 2003 Mudge do you have a link for the Hypertech files? One problem at looking at other files is that they are set up for 3.73 gears. Lonestar from what I can find, it looks like the Lt1 only uses mph to shift and not RPM. I tokk the rpm's up to 6000 to see if that would help. The program does ask for what gears you have, I wish they would program the trans table from the change in gears. Mike Quote Link to comment Share on other sites More sharing options...
