Compression #'s on turbo engine
Guest bastaad525
Guest bastaad525
okay I did a search on this one using "compression" "compression test" and "compression check" and didn't find anything...
I just want to know what are good compression #'s for an '81 turbo motor? I might test it today just for the heck of it.
My last turbo engine had 100-105 across all cylinders, and it ran well with no oil burning. The rebuilt low mileage engine I have now tested 125 across all cylinders. As long as you have less than 10 psi between, you should be good to go. By the way, I think compression test pressures are lower at altitude (I'm at 5280').
