Guest Child_inblack Posted August 19, 2003 Share Posted August 19, 2003 r clutch type lsd diffs good as opposed to viscous units? whats the difference? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 19, 2003 Share Posted August 19, 2003 Viscous LSD builds fluid resistance when one wheel spins at a different rate than the other, which is used to drive both at the same speed again. Clutch type is always preloaded to keep tires moving the same speed, and in Nissan's unit also is driven by torque. The more power you give it, the tighter it locks up. Clutches tend to chatter, and need to be replaced periodically. There are reasons for each: viscous won't make the front of the car push, but it does nothing until after one wheel starts to spin. VLSD is not torque sensing but it is slip sensing. The more the wheel slips, the more fluid pressure tries to stop it. Not adjustable. Smoother. Clutch type is adjustable, you can make it very aggressive, and it is torque sensing, but if you adjust it super tight then it makes your car push because it acts like a spool until you overcome the friction in the clutches. Adjustable. Not as smooth. I like clutch type units, FWIW. Jon Mortensen Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted August 19, 2003 Share Posted August 19, 2003 VLSD is not torque sensing but it is slip sensing. The more the wheel slips, the more fluid pressure tries to stop it. Not adjustable. Smoother. The VLSD is adjustable with different weight oils. For simpler terms with pictures, look at this link: http://auto.howstuffworks.com/differential.htm !M! Quote Link to comment Share on other sites More sharing options...
gramercyjam Posted August 19, 2003 Share Posted August 19, 2003 I have an R180 VLSD in my 240Z and it might as well be an open diff. So where do I get this heavier oil for it and how do I put it in? --John B '73 240Z Quote Link to comment Share on other sites More sharing options...
Guest Child_inblack Posted August 20, 2003 Share Posted August 20, 2003 thank u gize very much that helps a lot Quote Link to comment Share on other sites More sharing options...
