Guest Anonymous Posted August 26, 2003 Share Posted August 26, 2003 I have a small spearco intercooler it measures 2.5" thick, 5" high, and 16" wide the appearance seems rather small I Know the intercooler is fine it came of a buddies car, but do you think it will be worth plumbing in or should I just get a used npr intercooler. any help would be appreciated. Thanks [/img] Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted August 26, 2003 Share Posted August 26, 2003 The good thing about Spearco is their specifications. If you can get a part number for it, you can see what it flows and it's efficiency. I am using a Spearco about the same size; it's supposed to flow 650 cfm with their standard pressure drop (not sure, maybe 1/2 psi). The fellow I bought it from used to run 12s and high 11s. Maybe he was pushing it, maybe not, but it works well for me even though the inlet and outlet are just 2" OD. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted August 26, 2003 Share Posted August 26, 2003 A rough and safe rule of thumb on how much HP an I/C can support (before pressure drop) is to divide the advertised flow rate by 1.55. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted August 28, 2003 Share Posted August 28, 2003 Mine can support 677.42hp. Quote Link to comment Share on other sites More sharing options...
