Arif Posted August 26, 2003 Share Posted August 26, 2003 It been awhile since I posted and seems even longer since I have drove my Z. With a baby and a wife in Korea (dual military) don't have much time for the Z. Anyway I have a strange problem that I can't seem to diagnose. I replace the clutch slave cylinder on my Z. Before I tried to bleed the system I tried to start it up and I got nothing. The car doesn't even try to turn over. What could cause this?I have an SDS system on the car but I don't think that is the problem. What tells the starter to turn? I saw the ignition module on the passenger side and thought that might be it. Any suggestions? Quote Link to comment Share on other sites More sharing options...
fast eddie Posted August 27, 2003 Share Posted August 27, 2003 starter solenoid good? Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted August 27, 2003 Share Posted August 27, 2003 Is there an inhibitor switch on the clutch pedal? Did you move it, bump it or knock the wires loose? Quote Link to comment Share on other sites More sharing options...
jaime240z Posted August 27, 2003 Share Posted August 27, 2003 That sounds familiar. BTW what year is your car? Does this help?: http://hybridz.org/phpBB2/viewtopic.php?t=23529 Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 27, 2003 Share Posted August 27, 2003 If you were messing with the clutch slave (especially if you were working from the top of the car rather than underneath), did you possibly disconnect the fusible link that goes to the starter? I've bumped mine and disconnected it accidentally because the connector was old and loose. Jon Quote Link to comment Share on other sites More sharing options...
Arif Posted August 28, 2003 Author Share Posted August 28, 2003 Thanks. I will check all these suggestions this weekend and see if I can get it fired up. Quote Link to comment Share on other sites More sharing options...
