100 Posted September 5, 2003 Share Posted September 5, 2003 Will a 15 x 7 with a -9mm offset have any rubbing. Will this be flush with the wheel well or stickout or in too much? Thanks Quote Link to comment Share on other sites More sharing options...
johnc Posted September 5, 2003 Share Posted September 5, 2003 Might rub, not flush, too much in or out depends on what you think is too much. Quote Link to comment Share on other sites More sharing options...
100 Posted September 6, 2003 Author Share Posted September 6, 2003 Rub on fender or suspension? Quote Link to comment Share on other sites More sharing options...
johnc Posted September 6, 2003 Share Posted September 6, 2003 Probably suspension, but the only way you'll know for sure is to mount them on the car. Quote Link to comment Share on other sites More sharing options...
Guest billy383Z Posted September 8, 2003 Share Posted September 8, 2003 Also depends on what tire you intend to mount on your 15x7's...I have 205/60-15's mounted on 15x7's with -10 mm of offset, and the tire do not rub anywhere, and the front tires just BARELY rubbed the lower spring perch until I put a 5/16" spacer plate behind the front wheels. This effectively gives me only about -2mm of offset and NO rubbing. If I ran with a tire any larger than say a 215, I might have clearance problems with the rear tires. Quote Link to comment Share on other sites More sharing options...
DatsunBoy77 Posted September 8, 2003 Share Posted September 8, 2003 Wouldn't negative offset push te wheel out towards the fender? I thought the more positive offset the tire gets moved in like if you tried to put a fwd wheel on it hits the strut. Negative would do the opposite, right? Quote Link to comment Share on other sites More sharing options...
Guest billy383Z Posted September 8, 2003 Share Posted September 8, 2003 You know, I think you are probably right...I was exceptionally tired when I got in last night after putting about 300 miles on my Z yesterday. My wheels have 10mm of Positive offset, not negative. I suppose if my 15x7's had negative offset, they wouldn't need spacers in the front and wouldn't rub on anything. Quote Link to comment Share on other sites More sharing options...
