fl327 Posted September 17, 2003 Share Posted September 17, 2003 Just finished the swap into my car, idles a little better, nothing crazy, I just fired up the car for thirty seconds or so and then shut it off. I am wondering if anyone use this with msd 6 ignition box, im pretty sure it would work ok, just wondering. Swap was incredibly straight forward, just make sure to grab the coil harness plug with a good length of wire attached when you get one from a jy. blue from coil plug goes to blue from coil (-) green from coil plug goes to blk/wht from (+)z31 boom, sucker will fire right up, feels pretty strong too, at least as good as my Accel coil was doing it. Im wondering how the wiring from the z31 transistor works. The s130 transistor has two sets of wires, one from ecu and one for coil The Z31 only has three wires, one I am prettty sure is ground, Im not sure what has to be done here. It looks like you need to splice the two wires into four wires ( two to coil and two out to ecu power) and ground the black wire right?? Im dying to use use the z31 transistor, the coil already saved me a bunch of space, and now the s130t transistor looks really lonely with no coil in the bracket. thanx. Quote Link to comment Share on other sites More sharing options...
Guest nfZ1983 Posted June 28, 2006 Share Posted June 28, 2006 I have just bought a 84 300z and i really like it but it has issues high miles of course and exhaust and it seems to have a miss i am planning on doing ignition this weekend but im a little umm... lets say stupid about th z's and any ignitons anyway to the point I want to do a whole new ignition on the car i would like a msd box but i am wondering about what box to use, and where to start any comments would help thanx Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted July 3, 2006 Share Posted July 3, 2006 the stock z31 ignition is fine for 0-10,000hp, 0-7k rpm. The coil could be better, like an MSD unit, but it is fine, really. Quote Link to comment Share on other sites More sharing options...
znova Posted September 11, 2007 Share Posted September 11, 2007 Has anyone typed up a clear diagram for how to connect the three wires on the z31 transistor to the 280zxt " l- " connector? Ive tried searching but am having trouble getting a clear answer. Quote Link to comment Share on other sites More sharing options...
Kash Posted October 8, 2007 Share Posted October 8, 2007 How to install a z31 ignitor: blue wire - goes to y/w wire from zxt ecu pin #5 black/white wire - goes to negative side of zxt coil black - goes to ground Question: I did the swap today with a z31 coil on my s30 w/zxt motor, car runs strong and great; however my tach is all over the place with the z31 coil. The tach woks fine with the zxt coil and the z31 ignitor but when I switch to the z31 coil it is all over the place. Any idea? Do I need some kind of resistor for the hotter z31 coil to smooth out the signal to the s30 tach? Thanks. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted October 8, 2007 Share Posted October 8, 2007 That may be the case. Try something between 6.8k to 10k and see if that smooths it out. Mario Quote Link to comment Share on other sites More sharing options...
