scottyMIz Posted September 18, 2003 Share Posted September 18, 2003 hey guys i had a problem with my pump i replaced it about two months ago. Didn't put on a pre filter and i thought that was why it was making funny noises.I just changed my pump for a new one and the new one is loud too.I searched and couldn't find anything on the subject.The fuel filters both of them are good,haven't checked fuel pressure yet but will today.The only thing i can think of is that it's the return line maybe plugged?Anyone got any ideas?I do have it insulated so it's not touching the metal directly. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted September 18, 2003 Share Posted September 18, 2003 If you have the fuel injection pump a bad fuel damper will cause the fuel pump to be more noisy. Also check the rubber mounts on the rear pump. As they age they can harden up and transmit the pump vibration to the chassis. And a lot of the aftermarket "high performance" pumps are just louder than the stock Nissan pump. Quote Link to comment Share on other sites More sharing options...
scottyMIz Posted September 18, 2003 Author Share Posted September 18, 2003 it's prolly my prob being an aftermarket pump but it just seems to loud and gets louder the lower the rpm.The mounts are new and i have no dampener took it out was all rusty.Thanks Quote Link to comment Share on other sites More sharing options...
fl327 Posted September 18, 2003 Share Posted September 18, 2003 my pump got louder when i ran a relay to it. i run the dampener from stock 280z Quote Link to comment Share on other sites More sharing options...
scottyMIz Posted September 19, 2003 Author Share Posted September 19, 2003 ok guys return line is good must just be the pump.I was wondering what you guys ran for fuel pressure? Quote Link to comment Share on other sites More sharing options...
fl327 Posted September 19, 2003 Share Posted September 19, 2003 its not uncommon for me to turn it up to 55psi or so, street driving i run anywhere from 36-43. I like 43psi because that is supposed to be where an injector shoots its full stock cc value, 260cc in my case. Quote Link to comment Share on other sites More sharing options...
scottyMIz Posted September 19, 2003 Author Share Posted September 19, 2003 i was running 30psi of fuel pressure i think that's why it wouold dip lean then jump rich.I got it at 40 now and i'll see tomorrow how it runs.Thanks Quote Link to comment Share on other sites More sharing options...
