Guest DaMeat Posted September 22, 2003 Share Posted September 22, 2003 Finally got Zyas 1970 240Z, and I am in the process of putting the LT1 into it... but the oil pan on the motor I bought is a little smashed. I read in the JTR book that the oilpans for the TPI motors was different between the Corvette's and the Camaros... is this true with the LT1 motors as well? Would it be a good idea to get a Corvette pan (A little more clearance?) and a new pickup (Do I need antything else?) or stick with the stock Caprice oilpan like the motor already has? I tried the search but came up empty on this one. Thanks guys, and I am reading the hellz out of this site, there is so much good info. Quote Link to comment Share on other sites More sharing options...
mas28O Posted September 22, 2003 Share Posted September 22, 2003 I have the corvette motor in my Z but I think that the Camaro oil pan is the same. Good luck with the lt1 swap. Mike Quote Link to comment Share on other sites More sharing options...
gvincent Posted June 1, 2007 Share Posted June 1, 2007 Yeah I know this post is wicked old, but does anybody know if the Corvette LT4 oil pan will fit the JTR mounts? I am pulling my LT1 motor now and the bottom of the pan is pretty dented, I want to get a new pan and was wondering if there was any advantage to using the Corvette oil pan instead of ordering a Camaro oil pan. Or if there is a difference? Greg Quote Link to comment Share on other sites More sharing options...
piston Posted June 1, 2007 Share Posted June 1, 2007 i would think it wouldnt make any difference in the oil pan.... Quote Link to comment Share on other sites More sharing options...
bodie Posted June 2, 2007 Share Posted June 2, 2007 on the corvette oil pan the sump is longer and not a deep as a camaro pan since the frame rail crosses in the front below the balancer i see no reason why it wouldnt fit when i finish my motor i poan on a corvette pan, for the better ground clearance and extra quart of oil. Quote Link to comment Share on other sites More sharing options...
gvincent Posted June 4, 2007 Share Posted June 4, 2007 Bodie, So are you going to go with the longer Corvette pick-up tube or keep the shorter Camaro/Firebird one. Greg Quote Link to comment Share on other sites More sharing options...
bodie Posted June 5, 2007 Share Posted June 5, 2007 i dont remeber about the pick up tube and i dont have my gmpp book right now buy your pick up tube when you buy your pan , to be sure you get the right tube, esp if you buying a bolt on tube, the stock press on has a bit of adjustment if all else measure pan clearance using modeling clay should be 1/4 from the bottom corvette http://www.gmpartsdirect.com/performance_parts/store/catalog/Product.jhtmlPRODID=974&CATID=968.html camaro http://www.gmpartsdirect.com/performance_parts/store/catalog/Product.jhtmlPRODID=969&CATID=968.html Quote Link to comment Share on other sites More sharing options...
