Oil On Spark Plug Threads- Bad?
Did some research since posting and here are a few interesting links:
General info:
http://www.everything2.com/index.pl?node=spark%20plug
More info:
http://www.241computers.com/ford/ContentExpress20-80-81.html
(check the left pane for links on reading plugs, etc.)
This kind of stuff ought to be compiled for the newbies...
I read some of those links I posted ( always heed your own advice) and one mentioned proper tuqueing the plugs. As I remember, the plugs seemed to brake loose easily. Could that mean they could have been loose and the oil was seeping out from cylinder compression? Hopefully so. Otherwise, it would mean worn cylinder walls/rings.
Same with me. I tighten the plugs right, doesn't seem to be burning any oil and the other plugs are the right color. I think I will just assume the (old) plugs may have had looser threads and some oil seeped through.
Getting new plugs anyways. Wires, coil (which one?) and whatever other (consumables) it might need for this new owner.
