Velo Rossa progress: Fuel cell mount
Wagz
Yep, I had intended to build in a recessed battery tray too. However, the fuel cell takes up more space than I had intended. So, I'm going to have to surface mount the battery. I am thinking about mounting it between the strut towers with a cover in the same way Fiat Spiders have their batteries mounted.
Thanks Dan. Did you happen to see the post/question I had regarding cutting wheel wells? I think you have dealt with something I'm doing. I may PM you later if you don't see it.
Missed that one. Yes, I learned from someone with lots of experiance the best way to do that. Drop me a note before you start cutting. I can save you a lot of grief. No welder needed either.
