NHRA Seat belt rules
You can't be too safety concious. Do not just "go by the rules". To me if your going 11's a full cage, a 5 or 6 point harness, driveshaft loops, ect would be a minimum requirment. Your track should provide you a NHRA rulebook as a guide, but stay ahead of the rules. I try to at least follow the next more stringent set of rules. If you run 11's follow the rules for running 10's. Rick
Mike,
I'm using a stock seat with the 5-point harness. I cut a hole in the
seat back for the shoulder belts to pass through.
The shoulder belts mount(wrap around) to the back brace on the roll bar.
The lap belts mount to the factory lap belt locations, and the submarine belt
mounts to the brace that the front of the seat rails bolt to.
Guy,
All you need is a 5-point roll bar for 11's. The main hoop, two rear braces,
and a door bar on the drivers side.
:cheers:
Don
