cameraobsess Posted October 17, 2003 Share Posted October 17, 2003 hey i have a little problem.... i just got my 81 280zx running. it had been sitting for close to ten years, and i dont know much about how the earlyer owner treated it. i went to check the differential oil and both plugs are compleatly stuck. i used a breaker bar with a pipe attached and i still couldnt get it. i then tried to take the hole thing out of the car and all the nuts on the drive lines are stuck as well. what can i do?????? i have no clue what the oil is like in there and im woried if i keep driving it im going to damage it. i dont have another car to drive so im kinda stuck with it. any ideas would be a really big help!!! Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted October 17, 2003 Share Posted October 17, 2003 JB blaster... i think thats what its called... just spray it on, come back in like 12 hours to a day and it should be "takable" off. it worked for me.. some i couldnt take off, and took me a few days! mike Quote Link to comment Share on other sites More sharing options...
blueovalz Posted October 17, 2003 Share Posted October 17, 2003 If that does not work, a torch applied to the plug will loosen it up (breaking it loose while hot). Quote Link to comment Share on other sites More sharing options...
V8ZRACER260Z Posted October 17, 2003 Share Posted October 17, 2003 The spray is PB Blaster and like they said let it soak in and try it. If not then heat it up with a propane torch. Hav a spray bottle of water handy for any flare ups (Grease is flamable) This will expand the metal and hope fully break the rust bond. Rick Quote Link to comment Share on other sites More sharing options...
Tim240z Posted October 17, 2003 Share Posted October 17, 2003 I've found that this trick will work 100% of the time, at least it has for me. Heat up the female side of the threads (the diff casing in this example). Get it nice and warm. A heat gun for soldering from Home Depot will do the trick (use MAPP gas instead of propane, it burns hotter). Then, with wrench/ratchet ready, hit the bolt with a can of compressed air (holding upside down to get the liquid CO2 to come out). Then turn it loose. Tim Quote Link to comment Share on other sites More sharing options...
cameraobsess Posted October 18, 2003 Author Share Posted October 18, 2003 by heating it up i wont weaken the internal workings will I? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted October 18, 2003 Share Posted October 18, 2003 I doubt that you'll get the diff casing as hot as it would get at normal operating temp. You won't hurt anything. You don't need to get it red hot....just warm it up for about 90 seconds or so. Tim Quote Link to comment Share on other sites More sharing options...
cameraobsess Posted October 18, 2003 Author Share Posted October 18, 2003 thanks ill try that out next chance i get. Quote Link to comment Share on other sites More sharing options...
