Gear oil recommendations for the R230 VLSD
maichor
  • 1 year later...
Amsoil 75w-90 gear lubricant. The limited slip additive is also available.
Depends on how you use the vehicle (racing, autoX or street use) as to how long the fluid will last you.
Also remember, if you put clean oil in a dirty environment it`s going to get contaminated from all the nastiness left over from the previous lube. My recommendation (regardless of what synlube you go with) is to drain and refill with some quality petroleum product and run it for a 100 miles or so (to clean things) then drain and refill with synthetics.
  • 2 months later...
Guest JAMIE T
I am looking into fluids for my R230 VLSD. I can see the gear oil being used, but does a VLSD need a friction modifier additive? The VLSD doesn't have friction plates right?
Guest whyme
Red-line Shockproof 0-250 weight already has anti-chatter additive in it .So if you go that route don't add more. Also All I run period . It's worth the 7-8 bucks a qrt.
