engine build up question...
ok, i have a 350 block right now. im lookin for about 325-350 hp then i want to spray and get around 430-450 hp at the wheels. can any1 give me a good combo for this? i already have some long tubes. but what head/pistons + rods/cam,ect.. should i use to get this? i only need about 325-350 at the wheels off the bottle. THANKS!
For your 325-350 hp combo check out the hi-perf rebuild kit from northernautoparts.com with hyperutectic pistons, rings, bearings, gaskets, timing set, oil pump, Crane Energizer cam and lifters, only $299!!!! Add $150 if you want forged pistons. A set of SCAT rods with ARP cap screws is $250 (my choice over rebuilt stockers) add an aluminum intake, 650 double pumper and a set of 1 5/8 headers for an EASY 325hp. I'd also add the Vortec head conversion package from a GM dealer like Scoggin-Dickey with all the bolts, gaskets, intake and self aligning rockers. $1500 in parts and another $500 in machine work should net you closer to 400hp.
